09-23-2025 02:53 PM
I have not been able to get it to work since the BIOS update. I cannot revert because it was a security update and does not allow reversion.
 D.Bogarin
			D.Bogarin
			09-29-2025 11:59 AM
Hi, I'm from NI Tech Support. We're currently investigating this issue and would appreciate your input. Could you please share the following details?
Please share any other relevant information you think might help us review the issue, thanks in advance!
09-30-2025 08:23 AM
See reply here.
 LukeShaheen
			LukeShaheen
			10-01-2025 12:03 PM
The symptom is the same as above: the PXIe-4468 module shows up in NImax and passes self-test, but the PXIe-1090 does not show up in NImax, and cannot be used with the Python SW we use to run our experiments becuase trigger routes can't be found.
The same PXIe-1090 and 4468 plugged into a Dell Precision 3590 laptop work fine.
