Multifunction DAQ
Calling DAQmx.dll from Java: Is there a new version of DAQmx.dll NET C# library for CLR 4.0
I need to use the C# NET API from a java program, so I have been trying to use Jni4net library to bridge the dll over to Java. I'm getting errors however, because the version of daqmx.dll that I have was built against CLR 2.0.50727. Is there a version of the dll for CLR 4.0 (Corresponding to .NET 4.0 or greater)?
Alternatively does anybody know another way of calling daqmx.dll from java?
(3,293 Views)
Do you have the DAQmx.dll assembly or the C dll? If you have the .NET assembly, where did you get it from?
Best Regards,
T. Le
Vision Product Support Engineer
(3,242 Views)
Accepted by ekylNiUser
I ended up getting the version I had to work.
I have the DAQmx.dll assembly. I got it from an old software project developed for the device I'm working on. I assume the original developer got it from the driver disk from National Instruments.
(3,206 Views)
