06-11-2024 12:39 AM
I have bought NI-9174 chassis 6 months ago, does it require calibration on yearly basis?
Kumaresan
Solved! Go to Solution.
06-11-2024
07:13 AM
- last edited on
02-03-2026
07:06 PM
by
Content Cleaner
cDAQ chassis does not need to be calibrated.
See Finding the Calibration Interval for an NI Device [broken link removed 2/3/26; article no longer available]
12-10-2025 08:56 AM
Just curious, why NI DAQs don't require calibration? I'm sure those DAQ board's component might experience a deviation over a period. Anyone, have you experienced any such issues (~delta) while comparing DAQ output vs other instruments results?
12-10-2025 10:03 PM
It may be the case that the accuracy specs are wide enough to accommodate the component variation over time.
01-16-2026 09:29 AM
I came across this discussion while searching for information on the necessity to follow the NI calibration procedure for cDAQ Chassis and Controllers (cDAQ-917x).
The accepted response seems reasonable if the time base referenced (and verified) by the procedure is not used in any chassis involved applications.
However, it is not clear to me whether the chassis time base is only relevant when directly referencing chassis resources such as its counter/timers or if the time base is always being used.
Does anyone have any insight into what functions the cDAQ-917x chassis time base serves and whether the aforementioned NI calibration procedure may be considered 'optional'?
