Cable for 6020E
I have had a problem with the connector on the front of the 6020E. In using this unit for field work a couple of the pins have been damaged. I have been able to make them work, but I need a short extension cable. The box is mounted in a cabinet, so a short (20 cm) female to male cable would be ideal. A 68 Pin SCSI cable is the right pattern but a metal housing keeps it from mating. NI does not make any variety of cables.
Ideas?
Thanks!
Mick
(2,677 Views)
i can give you 2 female -female cable, 12 cm NI 186952A-04, scsi 68 pin flat ribon
for shipping costs from Germany
There are scsi connectors female-female on the market (PC - Backplane)
Ulrich
(2,673 Views)
