Multifunction DAQ
is there any horn tone testing equipment available in labview?
i would like to build a horn tone quality control equipment using labview6.1.
i have a doubt, that is it possible to create a system like this and how much it is useful.
also write me what are the existing equipment available in the market for checking horn tone.
thanks a lot.
(3,092 Views)
I am not an expert with tone quality tests but my experience with NI products says that this can definitely be done. I even found a document on ni.com that talks specifically about this type of applications. Check it out....
http://zone.ni.com/devzone/conceptd.nsf/webmain/B93592851D94732E8625692F0055E8C9?opendocument
-scraggs99
(3,081 Views)
NI has a few tools for this including the Dynamic Signal Acquisition devices and the Sound & Vibration Toolkit for LabVIEW. You could pair up one of those devices with a microphone and use the tookit to do tone detection, sound pressure level calculations, octave analysis and other measurements.
Also take a look at Audio Measurements Made Easy with LabVIEW tutorial.
(3,073 Views)
