Analog Output with 2 channels writing only one value to both channels
Hello, I'm running Labview 16 with DAQmx 16.1.0
I saw this behavior first in my application and also in the DAQmx analog output example vi (attached).
In my application, I was sending a 2D DBL array to write to the outputs a0 and a1. Even though the two channels in the input array had different values, only 1 value would be written to both outputs.
For example, if the input array was {[1,2,3,4],[40,80,120,160]}, the output on both channels would be {40,80,120,160],[40,80,120,160]}. When I switched the order of the channels in the input array, the other value would be written to both outputs. I've seen the same issue with inputting a 1D waveform array. The issue was there with the DAQ assistant and using the DAQmx blocks.
Why is this happening??
(3,060 Views)
What hardware are you using?
(3,002 Views)
I'm using a Ni USB-6001 Daq
(3,000 Views)
How are you measuring the output?
I tested the code you sent on a cDAQ, and each waveform is written separately across the individual channels.
How are you reading in the data?
Are you experiencing Ghosting?
What troubleshooting have you tried?
(2,981 Views)
Accepted by jazzzzz
Sorry this was a silly grounding issue.
It has been resolved.
If anyone in the future sees this thread, just check your wiring first
(2,973 Views)
