Accessing samples read with multi channel AI
Quick question regarding the samples read from the DAQ when using a range of channels. I understand when reading one channel at a time, Dev1/ai0, and accessing the array of samples. What if I wanted to read multiple channels, Dev1/ai4:6. How is this stored? When using the same functions: CreateAIVoltageChan, CfgSampClkTiming, StartTask, ReadAnalogF64 how am I to access each N samples for each channel? I read where it possibly stores in a 2d array but have not had much luck figuring out how to proceed with that in the functions. Thanks
(3,140 Views)
It looks like you are dealing with C++.  I'm not familiar with using DAQmx in C++, but I think this will be the same as in LabVIEW.
When getting multiple samples from multiple channels, the result is a 2D array.  I want to say that the row is indexed by the channel and the column is the sample number.
(3,136 Views)
Yes, forgot to mention I am working in CVI. But needless to say, I managed to get it working. Thanks for the input.
(3,133 Views)
