Multifunction DAQ
How to do simultaneous acquire and generate data continuously
Hi There,
Im having confusing around two weeks to settle my problems problem is I would like to apply synchronize acquire and generate data using DAQ .
I already check the example of daqmx synchronization internal clock however the generate waveform is only run Enoch do I :
a) Generate continuously analog signal which having different amplitude and frequency and the same time acquire this signal (after generate then acquire)
b) I don't not know how to modify the example of daqmx synchronization vi because this example only generate once signal and measure (in while loop)
I already go thru forums however none is helping me.The application is not regeneration signal however is a vary signal output based on the user control...
Thank you for your kind advice..
(2,911 Views)
Yes... I already solve the acquisition and generation....Just want to ask if i could run the acquire and generation in different while loop to improve processing time...Tried to use local variable however does seems going well...Need help again...tq
(2,894 Views)
