Multifunction DAQ
AI Differential Mode software settings
I need to use AI differential mode on NI 6014.
On the hardware side, I connect the two ends of the differential signal to pin AI0 and pin AI8.
On the software side, I am using C API provided by NIDAQmx on Linux. I looked through the C API functions and I did not find one for setting the AI differential mode.
My questions are:
1) Do I need to configure something at all on the software side?
2) Or no software configuration is actually needed and the data from "Dev/ai0" is already the AI differential signal that I need.
Thanks a lot
(3,772 Views)
Hi
In NI DAQ( legacy), there was AI_ configure function call to do this.
But I have not seen what is its equivalent in DAQmx.
Do this. Find the examples mentioned in this link and you might get a code that will help you find the equivalent function call in DAQmx
also do search in development library
Hope this helps
Regards
Dev
(3,765 Views)
Hi All-
The "terminalConfig" parameter of the DAQmxCreateAIVoltageChan() function selects the AI reference configuration to use.  Allowable values for the NI 6014 are as follow:
  • DAQmx_Val_NRSE   Nonreferenced single-ended mode
  • DAQmx_Val_Diff   Differential mode
Hopefully this helps-
Message Edited by Tom W [DE] on 07-25-2006 09:34 AM
Tom W
(3,757 Views)
Thanks! Problem solved Smiley Tongue
(3,747 Views)
Hi apd-
Glad I could help- good luck with the rest of your DAQmx experiment.Smiley Happy
Tom W
(3,743 Views)
