01-07-2009 09:19 PM
01-08-2009 03:12 AM
Hi Turbot,
Thanks for the post and I hope your well today.
I have no forgotten about the post you've made here: Does the polling fast enough.
Please don't post multiple times for the same issue. I will continue to support you in the main thread.
However, the answers your looking for can be found in this KnowledgeBase Article:
Why Does My USB DAQ Module Get the "Unable to Locate a Driver" Error?
http://digital.ni.com/public.nsf/allkb/42702DA4B800C73586257273006504B3
Most C Series modules work with
NI-DAQmx running on Windows. The two exceptions are the NI USB-9211
and the NI USB-9215, which originally used the USB carrier, USB-9161.
These model numbers are used when the modules are used in a USB-9161.
When used in this configuration, DAQmx Base is required, as DAQmx will
not recognize the units.
The difference between the USB-9161 and USB-9162 is that the USB-9161 works only with NI-DAQmx Base 2.2 or older.
Hope this helps,
01-08-2009 03:19 AM
Is there any memory or FIFO on 916x, or on 9229.
Need to garentee no data lost in the polling by the PC.
01-08-2009 03:28 AM
Hi Turbot,
Thanks for the reply.
As stated previously, I have replied to your previous question and this new one in the original thread:
http://forums.ni.com/ni/board/message?board.id=250&message.id=45546#M45546
