Multifunction DAQ
Problem with 't0' and 'dt' from DAQ Assistant resposnse
Hi
I am measuring digital signals at counter0 and counter1 using the DAQ USB-6281 for encoder measurement. I used the DAQ Assistant to configure
and measure the signals but in the wave form properties the 't0' comes empty and the 'dt' comes like 1 s.
Some one have any idea from what is this for problem??
Tanks
(2,933 Views)
Hi Allef,
Thanks for your post and I hope your well today.
Could you please post the code (VI) and what version of LabVIEW are you using?
How are you getting the t0 and dt values from the dynamic output of the DAQ assistant?
In the example finder there is an example titled 'Measure Angular Position.vi'.. does this work? If so, then it must be your code. If not, then it must be the way your producing the t0 and dt values.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,910 Views)
