‎07-17-2022 05:35 AM
Hello
I lost my usb cable of ni 4431.
I tried to use a printer cable but when I use the printer cable faced with "connected device not recognise" error
My question is:
1. Can I use USB 2 AB cable that exist in market or i should buy new USB cable from NI?
2. I couldn't find USB cable details that use for NI USB-4431. Can someone help me?
Solved! Go to Solution.
‎07-18-2022 12:39 PM
Any good quality USB A to B cable should work, these are standard cables that comply with USB standards
‎07-18-2022 02:23 PM
Thanks for your reply
I bought an original HP printer cable but thats not solved the problem.
After a lot of search I find out below information and my problem solved:
Every USB 2.0 Type A to B cables made of 4 wire, 2 wire for data and 2 wire for power.
There is a code for thickness of these wires called AWG
A good cable for NI devices must be
28AWG/2c+22AWG/2c
The second code must start with 22 or lower. It means the power wires are thick enough
For more information about this code you can read below:
https://www.google.com/amp/s/ikitcher.com/how-to-purchase-a-good-usb-cable/amp/
Every USB 2.0 Type A to B cables has made of 4 wire, 2 wire for data and 2 wire for power.
A good cable for NI devices must have below code
28AWG/2c+22AWG/2c
The important notice is that second code must start with 22 or lower. this means the power wires are thick enough to supply needed power for the device
For more information about AWG code you can read below article:
