 falkpl
			falkpl
			02-28-2007 03:09 PM
 AnalogKid2Digit
			AnalogKid2Digit02-28-2007 03:47 PM
Paul:
26 gauge solid, enclosed, can handle about 1.3 Amps, so it should do. Personally I would use 22 gauge for a good safety margin (5 Amps)
Smaller gauge = larger cross sectional area = larger current capacity. Other factors are ambient temp, solid vs stranded, frequency, tinning, but a rough guideline in the link below.
http://xtronics.com/reference/wire_gauge-ampacity.htm
-Pete
03-01-2007 07:04 AM
Thanks I figured I was going to need something in the ball park of 20-22 Gauge but I am a software guy so what do I know. Do you know if some one makes a standard connectorized 22 gauge DB9 cable or do I have to get out the soldering iron. I am trying to avoid reinventing the wheel since I have to make several of the same systems.
Paul
 Bill_5335
			Bill_5335
			03-01-2007 08:45 AM
You may have some luck with www.l-com.com
Since I hate to solder, I use pins that are crimped onto the wire. I do a lot of custom cable so the crimper cost is justified. I use components from Amp.
 Buechsenschuetz
			Buechsenschuetz
			03-06-2007 03:25 AM
03-06-2007 06:52 AM
 Buechsenschuetz
			Buechsenschuetz
			03-06-2007 08:14 AM
