Stepper Configuration Utility Software?
I am trying to get a stepper motor rig up and running and I am having an issue.  My setup and the process I am following is best described by this pdf:
http://www.ni.com/pdf/manuals/376090a.pdf
The issue that I am having is I am unable to communicate with the SMD 7620 motor drives and that I cannot find this NI Stepper Configuration Utility software that they refer to.  Has anyone heard of this software before or used his setup?
Message 1 of 12
(9,863 Views)
Hello PumpkinPie,
I've uploaded the Stepper Configuration Utility to our FTP site. The file is called "Stepper Motor Configuration Utility.zip". Here is the link. The webpage to download the utility is currently in the approval process, it should go live sometime next week. I will post a link to the download page in a response when it is online. Please let me know if you have any questions!
Ian K.
Software Developer
Data Ahead AG
Message 2 of 12
(9,831 Views)
Beautiful!  Thank you!
Message 3 of 12
(9,818 Views)
The NI Stepper Configuration Utility 1.0 is now online!
Ian K.
Software Developer
Data Ahead AG
Message 4 of 12
(9,713 Views)
Hello
I try to use Stepper Configuration Utility  1.03 but i have the error : " Erreur d'éxecution '13' : Type incompatible "
What can I Do ?
thanks for your help
best regards
Frédéric SOUDAY
Message 5 of 12
(8,364 Views)
Hi Frédéric,
Would you please post a screen shot of the error? Does this error happen at particular point in the program, eg when you search the network or open a configuration menu?
Message 6 of 12
(8,296 Views)
Hello;
NI France informed us that this error appened only with the french version of Windows. We must used Windows with English parameters and it's OK.
For information, after different tests, we find that Ethernet Axes as ISM7413 must be used only with Softmotion 2014 and Labview2014.
best regards.
Frédéric SOUDAY
Message 7 of 12
(8,292 Views)
Hello
I spoke with Jean-Claude Rutagengwa (Sr. Technical Sales Consultant ), he said that SP1 LV2015 and LV 2016 came out this week, so see if the problem is resolved.
Currently I have Windows 10 french, Labview English 2015 and English Soft motion in 2015 and I still have the error 13
The engine is the ISM-7413E
In fact what are the correct version for this to work for windows, Labview and soft motion
Thank you
Message 8 of 12
(6,958 Views)
The Stepper Configuration Utility software is somewhat useful at the very basic level (ie: can the PC communicate with the motor); however, a full set of drivers is really needed to support implementing a solution using LabVIEW.
Message 9 of 12
(6,214 Views)
I changed the window language to English and everything is correct
thank you
Message 10 of 12
(6,204 Views)
