‎06-05-2014 07:43 PM
I am trying to get a stepper motor rig up and running and I am having an issue. My setup and the process I am following is best described by this pdf:
http://www.ni.com/pdf/manuals/376090a.pdf
The issue that I am having is I am unable to communicate with the SMD 7620 motor drives and that I cannot find this NI Stepper Configuration Utility software that they refer to. Has anyone heard of this software before or used his setup?
‎06-06-2014 04:03 PM
Hello PumpkinPie,
I've uploaded the Stepper Configuration Utility to our FTP site. The file is called "Stepper Motor Configuration Utility.zip". Here is the link. The webpage to download the utility is currently in the approval process, it should go live sometime next week. I will post a link to the download page in a response when it is online. Please let me know if you have any questions!
‎06-06-2014 06:25 PM
Beautiful! Thank you!
‎06-18-2014 08:22 AM
The NI Stepper Configuration Utility 1.0 is now online!
‎09-09-2015 01:19 AM
Hello
I try to use Stepper Configuration Utility 1.03 but i have the error : " Erreur d'éxecution '13' : Type incompatible "
What can I Do ?
thanks for your help
best regards
Frédéric SOUDAY
‎09-15-2015 11:03 AM
Hi Frédéric,
Would you please post a screen shot of the error? Does this error happen at particular point in the program, eg when you search the network or open a configuration menu?
‎09-15-2015 12:13 PM
Hello;
NI France informed us that this error appened only with the french version of Windows. We must used Windows with English parameters and it's OK.
For information, after different tests, we find that Ethernet Axes as ISM7413 must be used only with Softmotion 2014 and Labview2014.
best regards.
Frédéric SOUDAY
‎08-08-2016 01:34 PM
Hello
I spoke with Jean-Claude Rutagengwa (Sr. Technical Sales Consultant ), he said that SP1 LV2015 and LV 2016 came out this week, so see if the problem is resolved.
Currently I have Windows 10 french, Labview English 2015 and English Soft motion in 2015 and I still have the error 13
The engine is the ISM-7413E
In fact what are the correct version for this to work for windows, Labview and soft motion
Thank you
‎01-09-2017 12:56 PM
The Stepper Configuration Utility software is somewhat useful at the very basic level (ie: can the PC communicate with the motor); however, a full set of drivers is really needed to support implementing a solution using LabVIEW.
‎01-10-2017 01:05 PM
