Motion Control and Motor Drives
Error using communicate front panel in Value Motion
I am trying to use the communicate front panel vi in the Value Motion vi library to communicate with my device. I have downloaded the latest versions of both Flex Motion and Value Motion.
I have opened Measurement and Automation explorer and sucessfully intitalized the device (a stepper motor with an encoder). So I don't believe there is an error in communication.
However, when using the vi "Communicate Front Panel", I recieve the error, "19: NIMC_noboardconfiginfoerror. Board configuration is missing or corrupt"
I'm not sure if I havn't properly configured the board in M&A Explorer, or that the Communicate Front Panel is not working well.
Any help is appreciated. Thanks.
(2,796 Views)
Are you using a Value Motion board or a NI-motion(flexmotion) board? The Value Motion Driver and VI's are only for Value Motion Boards and The NI-Motion(Flexmotion) driver and VI is for Ni-Motion boards.
A. Talley
Application Engineering
(2,796 Views)
Thanks for the help. I have a Flexmotion board.
I was using vi's previously developed by my co-workers that I belive mixed and matched Flexmotion and Valuemotion VI's. This might have been fine for their applications, but not for mine.
I developed my own script that uses only the Flexmotion VI's and it works fine.
(2,796 Views)
