 papaya
			papaya
			08-22-2007 09:14 PM
Hi Ima U
Installed NI daq 744(latest version) and Daqmx850. now I can run the getting started example for onepoine AI. and the NI435x vb60 example. also can add cwai on vb.net 2005 form listed NI pxi4351 and NI pxi4472.
Do you have example using cwai to control 4351 under vb.net 2005?or any advice?
Best Regards!
papaya
08-23-2007 07:54 PM
 papaya
			papaya
			08-23-2007 08:32 PM
Hi Ima U
Tested the NI435x driver2.5.1 cd example for vb60,can work well. for the reason that I had finished lots programm for pxi6221,pxi6225 and pxi4472, I still wanna program control NI 4351 under vb.net 2005. can we try use NI 4351 driver Lib unber vb.net?If there is no way to control Ni 4351 under vb.net 2005. I have to immigrate my programm from vb.net 2005 into vb60.
Best regards!
papaya
08-24-2007 02:49 PM
Hi papaya,
It is possible to program Traditional DAQ in VB .NET in Visual Studio with or
without Measurement Studio though it is difficult and we do not have any
examples I recommend that you take a look at the Knowledgebase article linked
below. Keep me posted if you have more questions.
 papaya
			papaya
			08-27-2007 08:38 PM
Hi Jordan D
Sorry for replying you late for busy on other things. Had read the document before which you mentioned. So I try to use Active X(Cwai control) component to do as the vb60 example,but seems the pxi4351 doesnt work as other daq board, needs lots configure to driver it as RTD or thermalocouple. and met the trouble how to convert vb60 varriant data into vb.net object data? after trying days, now wanna give up.(cwai.readsingle(data as varriant) which not be supported by vb.net).
Would you give me some examples for using active X to control pxi4351 unber vb,net?
Thanks!
papaya
08-28-2007 05:41 PM
 papaya
			papaya
			08-28-2007 11:54 PM
Hi Jordan D
you sugguest we try use vb imports nidaq32.dll, but I found the nidaq32.dll only supports these devices listed follow: there is no function to control ni435x device?
I guess that the ni435x.dll can support us to try this method to control ni4351 board?but whats the data type for "ViSession" to call function ni435x_init(VIrSRC resourcename,VIboolean IDQuery,VIBoolean resetDivice,VISession *DAQSession)
try this function call as (checkerror=ni435x_init("device1::2",true,true,"VI")),then get an error show me(cannot get return value).
more help?
Thanks!
papaya
NI-DAQ Functions Listed by Hardware Product
516 and LPM Devices
1200 Series
652X Devices
653X Devices
AT-DIO-32F
DAQCard-500/DAQCard-700
DIO-24 and DIO-96
E Series Devices (click here for a list of E Series devices)
I Series Devices
Lab-PC+
NI 5411 Devices
NI 622X
PC-OPDIO-16
PCI-6115
PCI-6120
PCI-6527
PCI-6703
PCI-6704
PXI-6115
PXI-6120
PXI-6527
PXI-6703
PXI-6704
VXI-AO-48XDC
VXI-DIO-128
Counter Devices
DAQCard-6601
PCI-6601
PCI-6602
PC-TIO-10
PXI-6602
PXI-6608
DSA Devices
NI 4451 for PCI
NI 4452 for PCI
NI 4454 for PCI
NI 4472 Devices
NI 4551 for PCI
NI 4552 for PCI
08-29-2007 06:35 PM
 papaya
			papaya
			08-30-2007 01:48 AM
Hi Jordan D
Lots time to uninstall lots NI driversi. lots time to reinstall Traditional daq744 and daqmx85.but I cannot find any function reference for tdaq744?read the tdaq744 readme,nowhere I can find the devices list that tdaq744 support and any information about PXI 435X? the NI-daqmx 85 readme list lots divices except the ni 435x deivice.who supports it?
search NI website, tell me these(
| Traditional NI-DAQ 7.4.4 - Windows 2000/XP11 ratings | 4.36 out of 5  Download(s)Download Language: English Product Line: Multifunction DAQ Version: 7.4.4 Software type: Hardware Driver Operating system: Windows 2000; Windows XP DescriptionTraditional NI-DAQ (Legacy) for PC Compatibles, version 7.4.4 for Windows XP/2000 Traditional NI-DAQ (Legacy) is an older driver with outdated APIs for developing data acquisition, instrumentation, and control applications for older National Instruments DAQ devices. Traditional NI-DAQ (Legacy) has the same VIs and functions and works the same way as NI-DAQ 6.9.3, except you can use Traditional NI-DAQ (Legacy) and NI-DAQmx on the same computer, and some hardware and software is no longer supported. You should use Traditional NI-DAQ (Legacy) only in certain circumstances. Refer to the NI-DAQ Readme for more information on when to use Traditional NI-DAQ (Legacy). To download NI-DAQmx, the latest National Instruments data acquisition driver, follow this link. Traditional NI-DAQ (Legacy) Installation Instructions:
Thanks for your help and your time. Would you give me more details for I am truely a new beginer to NI.
papaya
08-30-2007 04:17 PM
Hi Papaya,
I'm sorry for the confusion. This is a very old piece of hardware with very
little documentation. It seems that for some reason the support for the 4351
might have been lost in the final release of Traditional DAQ 7.4.4. Here is a
link to Traditional NI-DAQ 7.4.1 which definitely does
have support for the 4351.
