Measurement Studio for VB6
do other events while reading (daqmxread...) in VB6
I am new to using VB6 with NI-DaqMX (with C API).  I am trying to modify old VB6 code to work with a newer USB daq device (USB-6259).  I will eventually convert app to .net however the DAQ code I use is probably less than 1% of the total code.
I want to be able to do a read (DAQmxRead...(binaryI16, analogF64) of an analog signal for 3 seconds (300 samples).  Within that 3 second time I want to turn on and off some digital lines while the analog acq is taking place.
I tried the acqintclk sample (from VB6 examples), the code works, however VB6 does not continue on to the next line (which is PopulateListView... in the example).  I am used to using a CWAI control from Measurement Studio, that once the complete acq happens the acquireddata event would fire.
I was able to download another sample from the NI website (Cont Acq-Int Clk-Every N Samples Event (VB6)) filename: 200036.  This seems to work however I have a problem with it:
It seems alot more complicated than I need.  I don't necessarily need continuous, after I do the 3 second sample I will be done,  I can Start the task again later.  Is this
In the UI if I put in 300 (or anything a multipe of 3), I get the following error: Run-time error  '-200877 (fffcef53) - Requested Every N samples Event Interval is not supported for the given Data Transfer Mechanism and buffer size.
(7,774 Views)
Please see this forum post. It address the error you are seeing with the second code.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(7,748 Views)
Thanks for the info:
I found the solution earlier this week:  I used: DAQmxSetBufInputBufSize(taskhandle, 1200)
I have the following code in my app, I show you this to make sure it is in the right order.  It is working so I am just double checking with someone else.  Also, I am grabbing 300 samples from 4 analog (voltage) channels for 3 seconds.  I had my buffer at 3000 just to have some high number, but today I put it at 1200 just to fit exactly 1200 data points.  After I have the 1200 I save them to a file (and other arrays).
   DAQmxErrChk (DAQmxCreateTask("", taskhandle))
    DAQmxErrChk (DAQmxCreateAIVoltageChan(taskhandle, channel, "", DAQmx_Val_Cfg_Default, minVoltage, maxVoltage, DAQmx_Val_VoltageUnits2_Volts,    vbNullString))
    DAQmxErrChk (DAQmxSetBufInputBufSize(taskhandle, 1200))
    DAQmxErrChk (DAQmxCfgSampClkTiming(taskhandle, "", SampleRateTextBox.Text, DAQmx_Val_Rising, DAQmx_Val_AcquisitionType_ContSamps, samplesPerChannelPerRead))
(7,750 Views)
Your code looks correct to me. The order of the DAQ function calls also are correct.
Ima
(7,723 Views)
