web cam in measurment studio
I am using creative USB web cam i want to take some snap shot using measurment studio and vb.net i know vb and dot net framework i want to know how can i access web cam in measurment studio.
(3,991 Views)
Hello Dost,
National Instruments do a free IMAQ USB driver which can possibly be used but is not supported by National Instruments. The driver is potentially for use in LabVIEW however each VI (function) makes calls to various dlls which you can use from within VB. I am not sure how succesfully you will be here though. Anyway, here is the link to the driver:
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=ED6942DF78E34659E034080020E74861&p_node=DZ52490&p_rank=&p_source=Internal&p_submitted=N
You maybe able to use this driver for your camera, but check the supported cameras here:
http://digital.ni.com/public.nsf/websearch/89E33B77CFE244E986256F8E004E0F13?OpenDocument
Regarding displaying the images, the functions for the driver or your driver will return an image which you can display in a VB control. Measurement studio will not help you here.
Hope this helps.
Kind Regards
Steven Bird
(3,980 Views)
thnaks for the reply iam using vb.net will it work with vb.net
(3,978 Views)
Hello Dost,
This driver is produced for LabVIEW but uses the C alling conventions.
I have attached a word document that details all the functions and the dll etc so you should be able to call this from within VB however, VB is not supported and I cannot give support on the issue I am afraid.
Hope this helps.
Kind Regards, Steven Bird.
(3,970 Views)
Thanks for the reply but the link u provided in your reply does not work please check it.
looking forward for reply.
(3,873 Views)
(3,862 Views)
