Hello Dost,
National Instruments do a free IMAQ USB driver which can possibly be used but is not supported by National Instruments. The driver is potentially for use in LabVIEW however each VI (function) makes calls to various dlls which you can use from within VB. I am not sure how succesfully you will be here though. Anyway, here is the link to the driver:
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=ED6942DF78E34659E034080020E74861&p_node=DZ52490&p_rank=&p_source=Internal&p_submitted=N
You maybe able to use this driver for your camera, but check the supported cameras here:
http://digital.ni.com/public.nsf/websearch/89E33B77CFE244E986256F8E004E0F13?OpenDocument
Regarding displaying the images, the functions for the driver or your driver will return an image which you can display in a VB control. Measurement studio will not help you here.
Hope this helps.
Kind Regards
Steven Bird
Applications Engineer
