gpib, wait does not return after timeout
I use this code line:
gpibDevice.Wait(GpibStatusFlags.DeviceServiceRequest | GpibStatusFlags.Timeout);
I want to wait for a Service Request or a Timeout.
The IOTimeout is set to 1s, but the Wait function does not return after 1s.
What is the problem? Do I have to set any other timeout?
(6,478 Views)
pleasy refer to this documentation:
GPIB Wait Function
http://zone.ni.com/reference/en-XX/help/371361J-01/lvinstio/gpib_wait/http://zone.ni.com/reference/e...
Beste Regards
(6,444 Views)
Hi Gregor,
I am sorry but this link that you send, did not help me. I am using this code within a c# application. This is a bit
different to LabView. Here is my full code:
gpibAddress = 1;
timeoutValue = TimeoutValue.T1s;
gpibDevice = newDevice( 0, gpibAddress , 0 , timeoutValue );
gpibDevice.IOTimeout = timeoutValue;
gpibDevice.Clear();
gpibDevice.DefaultBufferSize = receiveBufferSize;
gpibDevice.SerialPollResponseTimeout = timeoutValue;
And I still have the Problem, that this Wait Function does not return after the
timeout value - here 1s. Do I have to configure anything else from the GPIB device?
(6,415 Views)
hi,
what is the state you get back from the gpibdevice.wait function? Is it 0? If not, what is it?
(6,393 Views)
Hi Gregor,
the problem that I have is that this device.wait function does not return because of a timeout. It is like a blocking call.
So I can not say what the result is.
Another problem that I have is when a device is connected and this device sends a SRQ, then
the wait function only returns when the timout value is larger than 1s.
Are this two problems connected?
When I set the timeout to 10s and a device sends a SRQ then I get
and
GpibStatusFlags.IOComplete
What can be the problem???????????????????
(6,388 Views)
Hi OnkiDonki,
If you use an OR operator in a condition, you should use the conditionnal Operator "||"
You can try :
gpibDevice.Wait(GpibStatusFlags.DeviceServiceRequest || GpibStatusFlags.Timeout);
Marc
(6,324 Views)
