C# - Digital input as trigger for analog input
Hi, I'm using a cDAQ-9188XT with a NI 9375 for digital inputs and a NI 9201 for analog inputs. I need to start reading an analog channel when a change from 1 to 0 occurs on a digital input and stop the reading on the next change from 1 to 0. Right now I'm using C# with an analog task that adds the readings to a List<Double> and a digital task that adds a Double.NaN to the same list when this change occurs, but my data seems to be out of phase due the read waveform samples buffer so I consider using triggers will solve that issue, but I haven't been able to find any documentation on how to achieve this.
Thanks in advance for your help with this.
(5,726 Views)
m0ndul,
Below is a CVI example with external triggering for synchronization. You can ignore the sections for signal output but the trigger method should prove useful for you.
http://www.ni.com/example/25881/en/
(5,695 Views)
