07-25-2013 04:17 AM
i've a Problem by Setting the Range of an GaugeDouble with MVVM
Here is my Code that doesn't work. Hope anyboy can help me:
<ni:GaugeDouble Range="{Binding GaugeRange}" Value="{Binding Value}" Width="auto" />
and in my Viewmodel
private Range<double> _GaugeRange;
public Range<double> GaugeRange
get { return _GaugeRange; }
set
_GaugeRange = value;
NotifyPropertyChanged("GaugeRange");
Thanks for your help
07-25-2013 10:27 AM
There is a known issue with how the numeric scale synchronizes its range with the numeric control when it is initialized. Instead of assigning Range only after it has been edited interactively, it will assign it when the scale is initialized, overriding the binding.
Instead, you will need to use a two-way binding:
<ni:GaugeDouble Range="{Binding GaugeRange, Mode=TwoWay}" ... />
07-26-2013 12:57 AM
Hi Paul,
thanks for your Answer.
I tried the Two-Way Binding but it doesnt work!
I have
GaugeRange = new Range<double>(-900,900);
Is that ok ?
What else can i try ?
07-26-2013 09:57 AM
Here is the complete example I used to test the two-way binding:
Code
using NationalInstruments.Controls;
using System;
using System.ComponentModel;
using System.Windows;
namespace GaugeRangeBinding {
public class Model : INotifyPropertyChanged {
private Range<double> _GaugeRange = new Range<double>( -1.0, 1.0 );
public Range<double> GaugeRange {
set {
NotifyPropertyChanged( "GaugeRange" );
public event PropertyChangedEventHandler PropertyChanged;
private void NotifyPropertyChanged( string propertyName ) {
var handler = this.PropertyChanged;
if( handler != null )
handler( this, new PropertyChangedEventArgs( propertyName ) );
public partial class MainWindow : Window {
public MainWindow( ) {
InitializeComponent( );
private void OnMouseUp( object sender, EventArgs e ) {
var model = (Model)textBox.DataContext;
var range = model.GaugeRange;
model.GaugeRange = new Range<double>( range.Minimum, 2 * range.Maximum );
textBox.Text = model.GaugeRange.ToString( );
XAML
<Window x:Class="GaugeRangeBinding.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:ni="http://schemas.ni.com/controls/2009/xaml/presentation"
xmlns:local="clr-namespace:GaugeRangeBinding"
Title="MainWindow" Height="300" Width="400">
<Grid>
<Grid.DataContext>
<local:Model />
</Grid.DataContext>
<ni:GaugeDouble Range="{Binding GaugeRange, Mode=TwoWay}" />
<TextBlock x:Name="textBox" MouseLeftButtonUp="OnMouseUp" />
</Grid>
</Window>
The XAML contains a text block that covers the screen, and clicking the text block causes the OnMouseUp handler to change the range on the model, which updated the gauge via the binding.
07-29-2013 02:48 AM
Hello Paul,
thanks for your Answer. Your Example works fine. but in my Case it isn't working.
I've got the GaugeDouble in an DataTemplate
<DataTemplate x:Key="Gauge">
<Grid ContextMenu="{StaticResource cmenu}">
<Grid.RowDefinitions>
<RowDefinition Height="30" />
<RowDefinition Height="*" />
</Grid.RowDefinitions>
<Label Grid.Row="0" Content="{Binding Title}" Padding="6,6,0,0" Background="#A0B2FF" BorderBrush="White" BorderThickness="1" FontSize="14"></Label>
<Border BorderBrush="white" Background="Gainsboro" Grid.Row="1" BorderThickness="1,0,1,1" Width="200"
Height="200">
<ni:GaugeDouble Range="{Binding GaugeRange, Mode=TwoWay}" Value="{Binding Value}" Width="auto" />
</Border>
</Grid>
</DataTemplate>
The DataTemplate is Used in an ItemsControl. That doesn't work. All other Controls where working fine.
What can be the Issue ?
07-29-2013 03:22 AM
Here is my complete Solution:
XAML:
<ItemsControl Grid.Column="0" Grid.ColumnSpan="3" AllowDrop="True" ItemsSource="{Binding Objects}" Background="Transparent"
x:Name="DesigningCanvas"
<ItemsControl.ItemsPanel>
<ItemsPanelTemplate>
<Canvas />
</ItemsPanelTemplate>
</ItemsControl.ItemsPanel>
<ItemsControl.ItemContainerStyle>
<Style >
<Setter Property="Canvas.Left" Value="{Binding X,Mode=TwoWay}"/>
<Setter Property="Canvas.Top" Value="{Binding Y,Mode=TwoWay}"/>
</Style>
</ItemsControl.ItemContainerStyle>
<ItemsControl.ItemTemplate>
<DataTemplate>
<Grid>
Height="200">
<my:GaugeDouble Range="{Binding GaugeRange, Mode=TwoWay}" Value="{Binding Value}" Width="auto" />
</Border>
</Grid>
</DataTemplate>
</ItemsControl.ItemTemplate>
</ItemsControl>
</Grid>
The Model:
private ObservableCollection<CanvasObject> _Objects;
public ObservableCollection<CanvasObject> Objects
get { return _Objects; }
set
_Objects = value;
NotifyPropertyChanged("Objects");
public Model()
Objects = new ObservableCollection<CanvasObject>();
Objects.Add(new CanvasObject
Height = 200,
Width = 200,
X = 100,
Y = 100
private void NotifyPropertyChanged(string propertyName)
if (handler != null)
handler(this, new PropertyChangedEventArgs(propertyName));
And here my Object:
public class CanvasObject : INotifyPropertyChanged
public CanvasObject()
private string _Name;
public string Name
get { return _Name; }
set
_Name = value;
Title = _Name;
NotifyPropertyChanged("Name");
private string _Title;
public string Title
get { return _Title; }
set
_Title = value;
NotifyPropertyChanged("Title");
private object _Value;
public object Value
get { return _Value; }
set
_Value = value;
NotifyPropertyChanged("Value");
private double _Width;
public double Width
get { return _Width; }
set
_Width = value;
NotifyPropertyChanged("Width");
private double _Height;
public double Height
get { return _Height; }
set
_Height = value;
NotifyPropertyChanged("Height");
private Range<double> _GaugeRange = new Range<double>(50, 900);
set
private double _X;
public double X
get { return _X; }
set
_X = value;
NotifyPropertyChanged("X");
private double _Y;
public double Y
get { return _Y; }
set
_Y = value;
NotifyPropertyChanged("Y");
#region PropertyChanged Event Implementation
private void NotifyPropertyChanged(string propertyname)
if (PropertyChanged != null)
PropertyChanged(this, new PropertyChangedEventArgs(propertyname));
#endregion
The Binding of the Range-Property doesn't work in this case. But why ?
07-29-2013 01:51 PM
With your full code, I was able to reproduce the issue. I am not sure why the binding is being cleared on a control inside a data template, as opposed to the behavior outside.
As a workaround, I have found you can use a binding on a custom attached property that assigns the range directly:
XAML
<ni:GaugeDouble my:Extensions.Range="{Binding GaugeRange}" />
Code
public static class Extensions {
public static readonly DependencyProperty RangeProperty =
DependencyProperty.RegisterAttached(
"Range", typeof( Range<double> ), typeof( Extensions ),
new PropertyMetadata( OnRangeChanged ) );
public static Range<double> GetRange( DependencyObject d ) {
return (Range<double>)d.GetValue( RangeProperty );
public static void SetRange( DependencyObject d, Range<double> value ) {
d.SetValue( RangeProperty, value );
private static void OnRangeChanged( DependencyObject d, DependencyPropertyChangedEventArgs e ) {
var pointer = (NumericPointer<double, double>)d;
pointer.Range = (Range<double>)e.NewValue;
07-30-2013 01:26 AM
It works perfect ![]()
Thank you very much 🙂
08-11-2015 12:24 PM
Just wanted to let you know the Range binding issue was fixed in the Measurement Studio 2015 release, and no longer needs the TwoWay mode workaround.
