wpf graph annotation target is hidden under the plot
Annotation target is hidden under plot and cannot be interacted with. Annotation label is positioned over the same plot and is draggable. Without plot everything works fine. When I zoom in enough so that plot isn't too thick, it also works fine. See attachment, there is barely visible annotation circle under the plot, and it cannot be moved. Only if I click at the circle part that is not covered by the plot, it can be moved.
Measurement Studio 2013, VS 2010, Windows 8 64-bit
(6,665 Views)
Unfortunately, this is a known issue in Measurement Studio 2013.
As a workaround, you can set the Graph.Position attached property to AbovePlots, so that the plots will not interfere with the annotation's mouse interaction.
~ Paul H
(6,652 Views)
Graph.Position is property of what class? Annotations don't have such property.
(6,641 Views)
Accepted by topic author eugenem
It is an attached property defined by the LayeredGraph base class. In code, you would use Graph.SetPosition( annotation, GraphLayerPosition.AbovePlots ); in XAML, ni:Graph.Position="AbovePlots".
~ Paul H
(6,635 Views)
Just wanted to let you know this issue (#351145) was fixed in the Measurement Studio 2015 release.
~ Paul H
(4,956 Views)
