Graph Name and Legend color settings
Ha!  So I copied the exact code I pasted (the one you said worked for you) and I don't get the error at ni: Plot
BUT, I get this error now...
Error 1 The namespace prefix "niPrimitives" is not defined.
We are getting really close LOL.  Is there something I need to define?
Thanks!
Message 11 of 15
(3,385 Views)
Accepted by kirko7
Yes, niPrimitives is another schema-based namespace:
xmlns:niPrimitives="http://schemas.ni.com/controls/2009/xaml/presentation/primitives"
~ Paul H
Message 12 of 15
(3,381 Views)
Nice!  Thank you...  I got this to work.
Altough the toggle button for every plot is not there anymore but I don't think I will need it (at least not now).
Message 13 of 15
(3,379 Views)
@phansen wrote:
Since you are generated plots in code, it may make more sense for you to override the default legend template for plots instead:
    <DataTemplate DataType="{x:Type ni:Plot}">
        <StackPanel Orientation="Horizontal">
            <niPrimitives:LegendGlyph Margin="3"
                    Renderer="{Binding ActualRenderer}"
                    Background="{Binding ItemBackground, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend}, Mode=FindAncestor}}"
                    Width="{Binding GlyphSize.Width, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend}, Mode=FindAncestor}}"
                    Height="{Binding GlyphSize.Height, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend}, Mode=FindAncestor}}" />
            <ContentPresenter Margin="3"
                    VerticalAlignment="Center"
                    Content="{Binding Label}" />
        </StackPanel>
    </DataTemplate>
Hi Paul.
Here I am more than a year later 🙂
Could you please post same XAML DataTemplate but only this time include the ToggleButton control?  I would like to try and substitute ToggleButton (that looks like default Windows style) with custom CheckMark.  So I need the complete DataTemplate to see how Plot visibility is bound to ToggleButton.
Thank you in advance!
Message 14 of 15
(1,977 Views)
Plot visibility is handled specifically by binding IsChecked on the ToggleButton to the plot's Visibility with {Binding Visibility, Converter={StaticResource VisibilityToBoolean}}, which uses this converter:
    <niPrimitives:MatchedValueConverter x:Key="VisibilityToBoolean" DefaultValue="Collapsed" DefaultResult="False">
        <niPrimitives:MatchPair Value="Visible" Result="True" />
    </niPrimitives:MatchedValueConverter>
If you are interested, here is the full style we use on the ToggleButton:
    <Style x:Key="LegendGlyphVisibilityToggle" TargetType="{x:Type ToggleButton}">
        <Setter Property="Width" Value="{Binding GlyphSize.Width, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend},Mode=FindAncestor}}" />
        <Setter Property="Height" Value="{Binding GlyphSize.Height, RelativeSource={RelativeSource AncestorType={x:Type ni:Legend}, Mode=FindAncestor}}" />
        <Setter Property="Margin" Value="3" />
        <Setter Property="Padding" Value="1" />
        <Setter Property="HorizontalContentAlignment" Value="Center" />
        <Setter Property="VerticalContentAlignment" Value="Center" />
        <Setter Property="IsChecked" Value="{Binding Visibility, Converter={StaticResource VisibilityToBoolean}}" />
    </Style>
The ToggleButton itself just wraps the legend glyph from the earlier template.
~ Paul H
Message 15 of 15
(1,972 Views)
