Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Debugger issues with NI DAQ
I'm having an issue with NationalInstruments.DAQmx.AnalogMultiChannelReader causing issues with Visual Studio's debugger. I'm creating an AnalogMultiChannelReader that runs in a new thread and continuously check for and reads incoming waveforms using ReadWaveform().
//Creating the DAQ task
private NationalInstruments.DAQmx.Task SampleTask;
SampleTask = new NationalInstruments.DAQmx.Task();
SampleTask.AIChannels.CreateVoltageChannel("Dev1/ai0", "", AITerminalConfiguration.Differential, 0.0, settings.DiodeLaserDaqMaximumVoltage, AIVoltageUnits.Volts);
SampleTask.AIChannels.CreateVoltageChannel("Dev1/ai1", "", AITerminalConfiguration.Differential, 0.0, settings.DiodeLaserDaqMaximumVoltage, AIVoltageUnits.Volts);
SampleTask.Timing.ConfigureSampleClock("",DLSampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, samplesExpected);
SampleTask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger("/Dev1/PFI2", DigitalEdgeStartTriggerEdge.Rising);
SampleTask.Triggers.StartTrigger.DigitalEdge.DigitalFilterEnable = true;
SampleTask.Triggers.StartTrigger.DigitalEdge.DigitalFilterMinimumPulseWidth = 0.0001;
SampleTask.Triggers.StartTrigger.Retriggerable = true;
SampleTask.Stream.Timeout = -1;
SampleTask.Stream.Buffer.InputBufferSize = 1000000;
SampleTask.Control(TaskAction.Verify);
SampleTask.Control(TaskAction.Commit);
//Creating the reader
private AnalogMultiChannelReader SampleReader;
SampleReader = new AnalogMultiChannelReader(SampleTask.Stream);
SampleTask.Start();
//Reading waveforms in the thread
if (SampleTask.Stream.AvailableSamplesPerChannel > 0)
AnalogWaveform<double>[] waves = SampleReader.ReadWaveform(samplesExpected);
However, if we run the application from Visual Studio with the debugger attached and try to close the application using the "Stop Debugging" option in Visual Studio while the reader's DaqStream is still running, both Visual Studio and the application become completely unresponsive, to the point of having to reboot the whole computer. I've been able to prevent this for crashes and manual shutdowns, but I can't find any way to prevent it when the debugger is forcibly ended. Does anyone know if this is a known issue or if there is a way to handle the reader that won't conflict with the debugger in this way?
Message 1 of 1
(1,468 Views)
