Checking License NationalInstruments LicenseException
Hello community,
occasionally, I run into the problem, that I have compiled something while the NI Pro license wasn't bound to my computer anymore. Afterwards, I am able to run the compiled program, thinking everything is good. But on the customer systems they will get a LicenseException after a certain time which causes all their automation-systems to stop.
Therefore a question: It is possible to insert a piece of code into my program which actively checks that this current assembly is compiled with a valid NI license rather than having a converyor-stop surprise on customer side with an .NET exception?
Somehow the assembly internally has to check this, too I guess to throw this exception.. can this be accessed actively to check if something is wrong so I know beforehand?
Thanks in advance
(2,408 Views)
Dear nicsp,
I suggest you contacting NI's support. Technical support representatives team, they should be able to help with thus kind of issue.
best,
anasei.
(2,318 Views)
