el 09-10-2008 08:40 AM
Hi NickB,
Thanks for your confirmation. I thought the same thing since I recognized the installation of NI still goes to the "Program Files (x86)". It is not 64bit yet.
I still happy with X86 target because it doesn't make difference for my project.
Thanks for your great help.
Tu
el 09-10-2008 11:12 PM
We are currently targeting late next year for providing 64-bit support with MStudio.
1) It would be helpful for us to know exactly what libraries you need 64-bit versions of (e.g., NationalInstruments.WindowsForms.dll, NationalInstruments.DAQmx, etc.). Could you post the list to this forum?
2) May I have permission to contact you directly, via email, to discuss your needs further?
David Rohacek
el 09-11-2008 12:46 AM
Actually, I didn't use any x64 bit feature in NI MS. However, I did use some in VB2005. But as I have to select the target CPU to x64 for compilation. That caused the problem. It did show some error messages on the dll that got problem but I forgot. I will try to compile again later and let you know.
Sure. You're always welcome to contact me via email.
el 09-11-2008 09:01 AM
Hi Drohacek,
I am working at Communications Research Centre in Canada. My interested development are Signal Processing and Analysis. I am developing the software to collect data as satellite receiver based on A/D card. The software should be able to calculate the power of signal and tracking the frequency from satellite at Ka-band. Real time measurement is very critial condition due to FFT performance. I am on the test with Matlab implement but it is not helpfull because it doesn't give graphical monitoring signal at real time.
I intended upgrade the operating system to Windows server 2008 with 64 bit for all our measurement. Thus, I need to try on the 64bit application. I hope Ni should continue support MFC libraries because most of kernel drivers for instrument are native C/C++. In addition, there is a lot improved features on MFC 9 from VS 2008.
Here is my list of component I use for all my projects:
NI-VISA *
Analysis
User Interface
Data socket
Excel
Legacy DAQ
You can contact me by email as you wish.
Thanks for your support.
Tu
el 03-09-2011 11:00 AM
el 03-10-2011 04:40 PM
darshan_09,
If you are using any libraries at all that are 32 bit, then you will need to build your executable targeted to x86, as discussed earlier in the forum. Doing that should mean that you do not need those extra pre and post build steps, since you really only have the option of building to x86.
Hope this helps,
Jen W
Applications Engineer
ni.com/support
el 03-14-2011 11:15 PM
I uninstalled NI Measurement STudio 8.5 and installed evaluation version of NI 2010 as suggested by NI. NI 2010 supports 64 bit WIn 7. But still I am getting same error. I am not able to understand why its not building a solution on Win 7? Please suggest.
el 03-15-2011 05:02 PM
darshan_09,
The error you posted points to Visual Studio 2005. In the readme for Measurement Studio 2010, it says in the installation requirements section:
Note Measurement Studio class libraries are designed to work on 64-bit operating systems. However, Measurement Studio class libraries for Visual Studio 2005 cannot be used to create 64-bit applications. To use Measurement Studio class libraries for Visual Studio 2005 on a 64-bit operating system, you must configure your projects to build 32-bit applications or libraries.
If you need to use 64-bit libraries, then you will need at least VS2008.
Regards
Jen W
ni.com/support
el 03-15-2011 11:30 PM
Thanks for your reply but Readme documentation itself mentions that it works on Visual Studio 2005. Actually, I am now able to build the Project. I Copied all NI dlls from GAC to local bin directory and it worked for me. But while running a solution, its not loading WIndows forms. I will keep you updating about this issue.
03-31-2011 08:23 PM - editado 03-31-2011 08:24 PM
Its not at all working. Solution is not building even though I have licensed copy of NI MS 2010. Please suggest what should I do as it becomes very critical issue and I am following with your support team and seems that they are also not able to solve this issue.
