Capacitance Conversion
How do I convert a Capacitance reading into the reading type?
What I mean by that is, say I get a reading like this 0.000000893544296332038
How do I convert it so that i get it as nF or uF etc.
I imagine its something to do with the range?
(2,908 Views)
Accepted by Gazlar
Here's some code I found a while ago that works very well.
private string ToEngineeringNotation(double d)
            double exponent = Math.Log10(Math.Abs(d));
            if (Math.Abs(d) >= 1)
                switch ((int)Math.Floor(exponent))
                    case 0:
                    case 1:
                    case 2:
                        return d.ToString();
                    case 3:
                    case 4:
                    case 5:
                        return (d / 1e3).ToString() + "k";
                    case 6:
                    case 7:
                    case 8:
                        return (d / 1e6).ToString() + "M";
                    case 9:
                    case 10:
                    case 11:
                        return (d / 1e9).ToString() + "G";
                    case 12:
                    case 13:
                    case 14:
                        return (d / 1e12).ToString() + "T";
                    case 15:
                    case 16:
                    case 17:
                        return (d / 1e15).ToString() + "P";
                    case 18:
                    case 19:
                    case 20:
                        return (d / 1e18).ToString() + "E";
                    case 21:
                    case 22:
                    case 23:
                        return (d / 1e21).ToString() + "Z";
                    default:
                        return (d / 1e24).ToString() + "Y";
            else if (Math.Abs(d) > 0)
                    case -1:
                    case -2:
                    case -3:
                        return (d * 1e3).ToString() + "m";
                    case -4:
                    case -5:
                    case -6:
                        return (d * 1e6).ToString() + "μ";
                    case -7:
                    case -8:
                    case -9:
                        return (d * 1e9).ToString() + "n";
                    case -10:
                    case -11:
                    case -12:
                        return (d * 1e12).ToString() + "p";
                    case -13:
                    case -14:
                    case -15:
                        return (d * 1e15).ToString() + "f";
                    case -16:
                    case -17:
                    case -18:
                        return (d * 1e15).ToString() + "a";
                    case -19:
                    case -20:
                    case -21:
                        return (d * 1e15).ToString() + "z";
                    default:
                        return (d * 1e15).ToString() + "y";
            else
                return "0";
Curt
(2,886 Views)
Thanks for that! Smiley Happy
(2,852 Views)
