C# read status of digital output line
Hello
Is it possible to read the status of a digital output line with a PCI 6509 board.
When i set a output line and read it back the output switches off because it set to input.
with kind regards
Tonnie
(5,758 Views)
Try this. Read back the values on the same task
using (Task digitalWriteTask = new Task())
                    //  Create an Digital Output channel and name it.
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/port0", "port0",
                        ChannelLineGrouping.OneChannelForAllLines);
                    //  Write digital port data. WriteDigitalSingChanSingSampPort writes a single sample
                    //  of digital data on demand, so no timeout is necessary.
                    DigitalSingleChannelWriter writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
                    writer.WriteSingleSamplePort(true, (UInt16)this.numericEdit1.Value  );
                    //  Create the reader
                    DigitalSingleChannelReader reader = new DigitalSingleChannelReader(digitalWriteTask.Stream);
                    //   Read back the value
                    this.textBox1.Text =  reader.ReadSingleSamplePortByte().ToString();
Hope this helps
Curt
(5,741 Views)
