Annotation support for WPF PolarGraph?
Does WPF PolarGraph support annotation? It seems that annotation is not supported, any other alternative ways to do this?
Thanks!
(3,099 Views)
Unfortunately, the positioning logic used by the point and range annotations was only implemented for the simpler Cartesian graph case. However, all of the graphs support custom IRenderable children, allowing you to implement any kind of custom annotation.
~ Paul H
(3,082 Views)
Thank you Paul.
I am not sure whether I can request demo code of implementing custom annotation from IRenderable.
Bob
(3,058 Views)
Accepted by Bob.Ter
Without other direction, I will guess you are interested in a point annotation. Here is a small example that renders a shape at a given data point:
public sealed class CustomAnnotation : IRenderable, IGraphChild {
    private readonly RenderTargetOptions _options = new RenderTargetOptions( null,
        RenderTargetOption.CreateValue( RenderTargetOptionsProperty.Fill, Brushes.Green ),
        RenderTargetOption.CreateValue( RenderTargetOptionsProperty.Stroke, Brushes.Black ),
        RenderTargetOption.CreateValue( RenderTargetOptionsProperty.StrokeThickness, 2.0 ) );
    private Point _dataPoint;
    public Point DataPoint {
        get { return _dataPoint; }
        set {
            _dataPoint = value;
            // Notify graph that data position has changed.
            OnInvalidated( RenderInvalidatedEventArgs.PositionalChange );
    public SupportedRenderModes SupportedRenderModes {
        get { return SupportedRenderModes.Vector; }
    public event EventHandler<RenderInvalidatedEventArgs> Invalidated;
    private void OnInvalidated( RenderInvalidatedEventArgs e ) {
        var handler = this.Invalidated;
        if( handler != null ) {
            handler( this, e );
    public void Render( RenderArgs renderArgs ) {
        // Get the relative position for the specified data point.
        Point relativePosition = _parent.DataToRelative( _parent.GetDefaultPlot( ), new[] { _dataPoint.X, _dataPoint.Y } );
        // Draw a shape centered at that position.
        Size size = new Size( 20, 20 );
        PointShape shape = PointShape.Diamond;
        renderArgs.RenderTarget.DrawShape( _options, relativePosition, shape, size );
    #region IGraphChild Members
    private IQueryableGraph _parent;
    public void RegisterParent( IGraph parent ) {
        _parent = (IQueryableGraph)parent;
    public void UnregisterParent( IGraph parent ) {
        _parent = null;
    public void Initialize( int index ) { }
    public void Uninitialize( ) { }
    #endregion
You could also use DrawShape to draw an arrow head (or use the drawing technique from this question), and use DrawValue to draw a string or other WPF content.
~ Paul H
(3,051 Views)
