03-07-2016 10:01 AM
03-07-2016 10:14 AM
Thanks for the link but unfortunately none of the steps or troubleshooting tips have helped.
-Art
03-07-2016 10:40 AM
03-07-2016 11:13 AM
Thanks for the tip. Do you know if NI VISA and its driver wizard supports USB3.0? From previous threads it was unclear.
03-07-2016 01:45 PM
I was see the help example some years ago for this wizard that was for camera dirver check that It is labview example to use this wizard
I hope it could help you
04-12-2016 03:23 AM
I also meet this problem so i want to know have you solve it?
04-12-2016 09:44 AM
We were using an xml generation tool and updating an older project for a new camera. We were able to solve our problem by starting the xml project from scratch for the new camera. I don't know why this worked since all the camera attributes are the same between the working and non-working xml files. There were some differences in the syntax of how these attributes were defined which must have been causing problems for the NI software.
Good luck!
04-14-2016 04:48 AM
Thank you for your answer .NI tell me the error is -1074360291(Unable to load camera's XML file). when I use this subvi after IMAQdx open camera function. I could acquire image.Do you know the reasons ? My English is not very good .Please forgive
04-14-2016 04:59 PM
Hi cjc,
It sounds like you’re now running into a different error beyond what the original poster of this thread did. It might be advantageous to start a new thread on the Machine Vision forum to address this new error.
Kind Regards,
05-03-2016 06:26 AM
i want to use labview to capture pictures from a camera, but NIMAX cannot recognize the camera's icd file writtn by camera file generator, but the same file can be recognized on the same Ni data acquisition card . i have tried to reinstall the NI MAX, but it still cannot be recognized.
