02-15-2005 04:02 PM
02-16-2005
12:10 PM
- last edited on
11-11-2025
10:21 AM
by
Content Cleaner
Hello robinchagoya,
Thank you for contacting National Instruments.
Since the 1409 is multiplexed, it sounds like the timing signals on the cameras are not synchronized. If your cameras are not genlocked (synchronized), then the frame rate will be reduced in order to allow for reconfiguring the acquisition. Note that you will need IMAQ Vision to use the WindDraw VI. If you do not have Vision and you are using LabVIEW 7.x, you can replace the WindDraw VI with an Image Display Control on the front panel.
Are these examples similar to the VIs you are using?
I cannot be certain what is causing this particular issue. If changing the board fixed the issue, then the problem may be hardware related.
Best Regards,
Jesse D.
Applications Engineering
