Machine Vision
cell count
Good day. I'm a student from Shenyang Institute of  Chemical Technology. Currently, i'm doing a study on red blood cell count. In order to count the total number of cell, I use NI Vision develop module to process the impage,First I use sobel filter to  extract  the outer  contour of the blood cell, then I use threshold to select the cell ,after that I find a lot of  cell are connected with eacher other so tightly, I have use separate function to deal with the impage but it no use, I hope somebody can give me a good idea, Thanks very much.
With regards,
ANLI
(3,794 Views)
能不能给张图片我看看!
(3,788 Views)
Hi ANLI!
Could you upload a couple of sample images for us to look at? It would be best to get the "raw" and unprocessed images directly from the camera.
If I understand you correctly, you are trying to count the number of red blood cells, but you have problems with separating them, correct?
Have you tried using a distance transform or Danielson algorithm?
Or, are you using blob analysis with an erosion function?
I am trying to understand your problem better. Maybe it would also be good, if you could describe how you are attempting to do the segmentation of the image.
Best,
Markus Tarin
(3,770 Views)
