Machine Vision
basler A60f-2
Hi! I am doing the final project degree in industrial electronics and automatic engineering.
I am using the camera BASLER A601f-2 and have trouble capturing the image, apparently grayscale saturates and does not capture well the objects.
Can anybody help me?
Thanks.
(3,993 Views)
Hi need more detail to look into actual issue.
-How you are capturing image?
From LabVIEW post code, From MAX Post screenshot of settings.
uday
(3,983 Views)
I am using vision assistant for image processing. I've been watching with my teacher at MAX in case it was some adjustment problem but no. We think that the camera has a problem, it might be the diaphragm?
In the image above you can see the failure.
Thanks.
(3,977 Views)
You could either reduce the exposure time or close the aperture some on the lens.  Another option is to reduce the gain.  If none of those work, it is probably a problem with the camera.
Bruce
Bruce Ammons
Ammons Engineering
(3,962 Views)
It also could be an issue with a multibyte format. FireWire was not as well standardized in this regard as the newer standards that replaced it. You may want to try switching the pixel format to an 8-bit mode or try changing the bit depth, endianness, or shifting mode and see if that helps.
(3,940 Views)
