Machine Vision
取消
顯示結果
搜尋替代
您的意思是:
ball tracking in live video
How can we perfrom ball trackning in real time using video camera.
0 積分
1 條訊息(共 14 條)
4,865 檢視
In order to point you in the right direction, I'm going to need more information from you.  What kind of video camera is it?  We certainly have plenty of algorithms which would allow this type of capability, but what software environment are you planning on using?  Thanks for anything additional information you can provide!
Cole R.
Software Engineer
0 積分
2 條訊息(共 14 條)
4,847 檢視
Dear Mr. Cole,
Thanks for ur reply. I am planning to use one or two  high frame rate  camera to track the moving ball tregectory and I want to predict the location where the ball will strike the ground using any estimation algorithm.
0 積分
3 條訊息(共 14 條)
4,833 檢視
we are going to use LabVIEW 2012 with vision tools.
0 積分
4 條訊息(共 14 條)
4,833 檢視
Hey,
Check this might help you.
Silver_Shaper | CLD
0 積分
5 條訊息(共 14 條)
4,797 檢視
You should also check out this link and make sure that your camera will be supported by the Vision Acquisition Software.
http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F
Cole R.
Software Engineer
0 積分
6 條訊息(共 14 條)
4,778 檢視
Dear Mr. Cole,
Thnaks for the reply.
The VI at ur given link is giving error. One of the sub VI is missing at that link.
I will try to find some compatibale high speed camera for the project
I think I need to implement Extended Kalman Filter to predict the point of impact. Could you or anyone please guide me how to implement EKF on live imagaes to predict the ball position.
0 積分
7 條訊息(共 14 條)
4,767 檢視
Before you get to that point, you are going to have to be able to detect the object and determine its location.  Have you started developing any algorithms in LabVIEW for this that will return this data?  The extended kalman filter is available in the control, design, and simulation toolkit.
Cole R.
Software Engineer
0 積分
8 條訊息(共 14 條)
4,735 檢視
Well we are planning to develop some algorithm the identify the ball  by its color or shape.
0 積分
9 條訊息(共 14 條)
4,720 檢視
I'll give you a bit of advice straight up.
Make sure the lighting is good as that will help prevent shadows which can cause problems.
0 積分
10 條訊息(共 14 條)
4,686 檢視
