在 09-11-2012 02:33 AM
How can we perfrom ball trackning in real time using video camera.
09-12-2012 01:13 PM - 已編輯 09-12-2012 01:14 PM
In order to point you in the right direction, I'm going to need more information from you. What kind of video camera is it? We certainly have plenty of algorithms which would allow this type of capability, but what software environment are you planning on using? Thanks for anything additional information you can provide!
在 09-13-2012 01:39 PM
Dear Mr. Cole,
Thanks for ur reply. I am planning to use one or two high frame rate camera to track the moving ball tregectory and I want to predict the location where the ball will strike the ground using any estimation algorithm.
在 09-13-2012 01:41 PM
we are going to use LabVIEW 2012 with vision tools.
在 09-16-2012 12:23 AM
You should also check out this link and make sure that your camera will be supported by the Vision Acquisition Software.
http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F
在 09-17-2012 03:02 AM
Dear Mr. Cole,
Thnaks for the reply.
The VI at ur given link is giving error. One of the sub VI is missing at that link.
I will try to find some compatibale high speed camera for the project
I think I need to implement Extended Kalman Filter to predict the point of impact. Could you or anyone please guide me how to implement EKF on live imagaes to predict the ball position.
Before you get to that point, you are going to have to be able to detect the object and determine its location. Have you started developing any algorithms in LabVIEW for this that will return this data? The extended kalman filter is available in the control, design, and simulation toolkit.
在 09-18-2012 10:13 PM
Well we are planning to develop some algorithm the identify the ball by its color or shape.
在 09-20-2012 07:27 PM
I'll give you a bit of advice straight up.
Make sure the lighting is good as that will help prevent shadows which can cause problems.
