Machine Vision
avi image extraction and save
Hi, I have a video in avi form which I would like to segment by each frame and save the image as a tiff. Ive done this in a while loop but it doesn't work. anyone know why?
thanks
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
(3,654 Views)
Accepted by Stephen1995
Hi Stephen,
For file path input, please give complete path including file name for each file.
-Currently directly you are giving application directory as path, to that append the following
-Since you need each image to be saved first get the iteration number and convert to decimal string and concatenate it with .tiff
-Use the resulting string as input to Build Path and base path from application directory.
-Pass the appended path to IMAQ Write File2 VI.
Let me know if it works.
uday
(3,645 Views)
I spotted my mistake just after posting and I'm pretty sure I did exactly what you put andown it worked. Thanks for the reply
CLAD
(3,643 Views)
