Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
02-13-2017 04:04 AM
Hello everybody,
I wanted to install the VDM software evaluation from the NI website in order to activate it later. after i loged in, this message appears to me, i didn't understand what to do next.
Thanks for your help in advance.
02-13-2017 04:24 AM
02-13-2017 04:39 AM
Thank you sir for your quick answer,
after installing CVI 2015 SP1 , and then installing the VDM evaluation, does it include the vision assistant with its easy to use interface? or should i install the Labview to open it and the generate the C code for my CVI ?
02-13-2017 04:45 AM
02-14-2017 02:40 PM
Hi!,
You can try to search for it at the Windows search bar to determine if the VDM installed it. If not, try running the installer file again to make sure you selected it in the "features to install" section.
Daniel C.
