Machine Vision
VDM evaluation Installation steps probleme
Hello everybody,
I wanted to install the VDM software evaluation from the NI website in order to activate it later. after i loged in, this message appears to me, i didn't understand what to do next.
Thanks for your help in advance.
(3,953 Views)
Go to below link:
http://www.ni.com/gate/gb/GB_EVALTLKTSIGPROC/US
-Click on download module under NI VIsion Development module.
-This will download an exe NI downloader.
-Click on the exe to download the Vision Development module and install for evaluation.
uday
(3,946 Views)
Thank you sir for your quick answer,
after installing CVI 2015 SP1 , and then installing the VDM evaluation, does it include the vision assistant with its easy to use interface? or should i install the Labview to open it and the generate the C code for my CVI ?
(3,941 Views)
I am not familiar with CVI.
-It does include Vision Assistant.
uday
(3,936 Views)
Hi!,
You can try to search for it at the Windows search bar to determine if the VDM installed it. If not, try running the installer file again to make sure you selected it in the "features to install" section.
Daniel C.
(3,910 Views)
