Machine Vision
Stereo Vision Calibration
Hello Everyone...
Can any one plese explain the GRID Calibration procedure for a Stero Vision Application in LabVIEW along with the following queries realted to the same.
1) Would Grid Calibration will provide the 3D Position information of a Object?
2) Is it possible to  prepare a test Srereo setup for Stereo Vision using USB Cameras(WEB Cams)?
3) How to confind the Field of View of the Camera to a certain Area of  e.g 100x100x100 mm ?
(4,882 Views)
perhaps the following links can help you a bit:
https://decibel.ni.com/content/blogs/kl3m3n/2014/07/24/stereovision-in-labview-based-on-correspondin...
https://decibel.ni.com/content/blogs/kl3m3n/2013/07/26/stereo-setup-parameters-calculation-and-labvi...
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,866 Views)
