Machine Vision
Reset Counter in VBAI with Button control
Hi, I developed a program of presence/absence.
I am counting the number of Pass of particular tool but not the whole inspection and displaying it in inspection interface.
Now, I want to add a Button to reset the value (Reset the counter) in Inspection interface. Please suggest how we can implement this reset button .
(2,442 Views)
Accepted by JN_23
Hi nirmitjain,
Please post your inspection and some screenshots from your state diagram otherwise no one can lead you in a correct way you need. Because the question which you asked can have different solutions and people can suggest you which is suitable for your application.
As a suggestion, create a "WAIT User Interaction" state in your state diagram. And whenever the Boolean Control is pressed, switch state to "Reset Counter" state in which you set the counter value to "0" (zero) constant.
I hope this will help.
(2,355 Views)
Hi sevincom,
Thanks you for suggestion.
It worked for my program.
NJ
(2,346 Views)
