09-26-2013 06:26 PM
I am working with an application that requires the Vision Run-Time Engine. After installation, if the Vision Run-Time Engine is not activated I get a pop-up (Vision Evaluation notice) that is behind my main application window. The pop-up is launched when I am running an analysis with the application (I assume the pop-up is invoked when I am calling a Vision Development VI). It appears to the user as if the application hangs. I can force the pop-up to be frontmost so the user will see the window. However, I'd like to be able to programatically determine if the Vision Run-Time Engine has been activated. This way I will not have to continue to poll for this window after it has been activated. Is there a way to do this?
Also, suggest that this pop-up window should be made front most so this work around isn't necessary. Please take a look into this NI R&D.
Thanks!
Brooks
09-27-2013 08:43 AM
