Machine Vision
Interactive overlay grid
my program acquires images from a camera.
Over this image I need to overlay a grid shown underneath.
The grid should be solid but must be placed interactively.
I am looking for a possibility to place the grid interactively inside the aquired image, that means that I need the ability to move and to rotate the grid inside the image.
Afterwards I need the position of the grid and especially the center points of each grid element (marked as points)
Does somebody have an idea how to solve this problem?
Thank you in advance !
(4,361 Views)
I would use the Overlay functions.  You can combine a bunch of Overlay commands to create the box (draw line, draw point, etc.) in a single VI.  I would probably use the center of the box and the rotation as the inputs.  You would need to use a little trig to figure out the coordinates.  Just acquire the image, call the Overlay Box VI, then display the image.
Bruce
Bruce Ammons
Ammons Engineering
(4,345 Views)
