SEQEng -
Actually, the CalculateCoefficients method has bene obsoleted as well. The new equivalent is ParticleMeasurement, and I think the call you would want to make is:
COleVariant vCenterMassXResults;
m_imaqVision.ParticleMeasurement(imgResult, cwimaqMeasurementCenterMassX, vCenterMassXResults);
If you prefer to use the CalculateCoefficients method, you need to call m_imaqVision.Particle() first, and pass the CWIMAQFullParticleReport from that to the CalculateCoefficients method. However, the ParticleMeasurement and ParticleReport methods support more measurement types, can take calibrated measurements, and are in some cases faster than their obsoleted equivalents.
Greg Stoll
IMAQ R & D
Greg Stoll
LabVIEW R&D
