06-21-2005 04:49 AM
06-23-2005 06:39 AM
06-23-2005 08:10 AM
06-27-2005 04:25 AM
07-01-2005 02:16 AM
07-04-2005 03:35 AM
07-13-2005 05:06 AM
Hi TimoS
my application was working before I needed a new PC. On the old PC was Win2k and I use IMAQ 3.01.
The new PC has WinXP SP2 and I use IMAQ 3.1.1. The application is still working, only the first time to take a shot the error appears.
- the cables are ok
- I can't check the signals because this is the only IMAQ device I have.
- The camera is always powered on before the PC
- I tested a different pci slot put the same problem.
regards ISOS
09-12-2005 08:12 AM
i have seen the same problem. I have written a workaround for this,
means i ignore the first error and setup a 2nd grab command. That is working.
We have also tested different Motherboards, slots, grafikcards.. but no effect. With the PCI1409
there is no problem in the same enviroment.
We change also the driver NI-IMAQ 3.1.3 -- No effect
10-12-2005 08:32 PM
10-13-2005 03:32 AM
I still haven’t found a solution. Next thing I will try is to update my VBAI Software, but I think it won’t solve the problem
Best regards to all companions in misfortune
ISOS
