Machine Vision
OCR attribute
Hi guys,
I am having an issue with performing an OCR function test. The error i receive back is IMAQ OCR Attribute  -1074395583. This has only happened today after I made modifications to an existing application. I have not had any issues with this before and also have nt made any updates to suggest this was the cause of it. I am wondering if it is a directory issue that it cannot find the file?
Damien
(5,433 Views)
Help>Explain Error>> in Code you enter your error code to get exact description why it happened.
-For the current error code, it shows "Character spacing must be >= 1 pixel" what value have you given to this??
uday
(5,429 Views)
Thanks for the quick response where do i find this parameter? Is it within the OCR character set?
Damien
(5,426 Views)
Accepted by Damien129
I'm not sure unless i can see the code and ocr character set( if you can provide,it'll be easy to find out where it happened)
-You said you modified application, did you edit the code or the character set file?
-Are you using vision assistant or labview?
-Check the character set file's Min character spacing in NI OCR Training Interface.
uday
(5,419 Views)
