08-11-2008 02:24 PM - edited 08-11-2008 02:25 PM
I discovered that there is a line detector already in the IMAQ searching and matching palette. It seems to do a pretty good job. The attached vi lets you select line detection settings, open an image file, select of region of interest and then displays detected lines on the original image. Help text is selectable from the front panel. Experiment with the settings to improve the results. The line detection image updates as you adjust the settings.
root
08-11-2008 05:02 PM
08-13-2008 07:00 AM
Thanks for the help........line detection tool is working fine for this seat but not working properly for the other texture.....
Warm Regards
Orooj Ahmed
08-13-2008 07:16 AM
08-14-2008 01:35 PM
In version 8.5 of the Vision Development Module, NI introduced a new advanced straight edge detection tool that uses several different algorithms. One of them is a Hough-based edge detector that worked very well on the three images in this thread. In version 8.6, we included these algorithms in other edge dection tools like the circular edge detector.
Kyle V
08-14-2008 02:56 PM
