Machine Vision
IMAQ copy buffer error
Can anyone tell me why I get this error with the following code?  It is a snippet from a larger app that uses copy image acquisition buffer to display multiple images in a while loop.  I extracted the offending code and I still get the error so it is isolated to the copy image acquisition buffer vi which kicks out a "cannot resize image in an acquisition buffer" error.  A similar application I have written works fine, so I know the methodology is sound, but the IMAQ version is older in the other app (3.1) and I used IMAQ copy instead which is now deprecated in 3.8.
(3,933 Views)
Dear ET,
The you are trying to copy back into the acquisition buffer. You need to supply a different buffer to the IMAQ Copy Acquired Buffer VI.
Best Regards,
~Nate
(3,908 Views)
Yes nate is right.The buffer is getting overwriiten.Provide a another buffer with a unique name
(3,888 Views)
