12-30-2014 08:10 PM
Hello, currently I have a automation project.
We are using an FANUC Robot (M20iA) with an FANUC R30iA Controler, a Lanoptik Camera and a computer on which we installed your niVision-Software.
Our project is about detecting a part with a camera, pick it up with orientation (angle) and place it somewhere else.
The Software is working really good with the camera. We are able to detect a part and it's orientation, but we have a problem to get the coordinates and transfer them via an Ethernet-Connection to the robot.
We tried to set up an OPC-Server with the vision software, but we don't know how to load the coordinates onto the server.
The connection between camera and computer is working. We could ping the PC from the Robot and the robot from the PC.
Have you any idea how we can fix our problem?
01-02-2015
07:42 AM
- last edited on
05-05-2026
12:38 PM
by
Content Cleaner
please have a look at the following documents:
Using Vision Builder AI as an OPC Server - National Instruments
http://www.ni.com/white-paper/13574/en/
Community: Tutorial: Using Vision Builder AI as an OPC Server - National Instruments
https://forums.ni.com/t5/Community-Documents/Tutorial-Using-Vision-Builder-AI-as-an-OPC-Server/ta-p/...
How Do I Use OPC in LabVIEW? - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MwxSAE&l=en-US
Also there is this similar thread:
Read and Write with OPC through NI Vision - Discussion Forums
https://forums.ni.com/t5/Machine-Vision/Read-and-Write-with-OPC-through-NI-Vision/td-p/2048278
I hope this helps!
03-04-2015 07:32 AM
For one of my project, i am planning to use the FANUC iRobot and communicate with LabVIEW. So I interested to know whether you are able to talk with OPC. If yes, could you share your experience which will be really helpful
Prithivi
07-29-2015 11:54 PM - edited 07-29-2015 11:55 PM
I have ever used a Lanoptik camera (14MP USB 3.0) in a similar project. I think you should ask for technical support from Lanoptik. You can try to download some functions or SDK from their website www.lanoptik-camera.com
09-20-2023 08:46 AM
Hello
I've personally used from ImageProvision. You should ask technical team of ImageProvision. They will give u a perfect solution for you. I've mention here website https://www.imageprovision.com/
